G50/52 Leak Repair
Hello, and thanks for your help in advance. I have a G 50/52 gearbox I am running
in a Ford GT 40 replica. I purchased the transaxle new and it had been modified for inverted use.(Powerhouse) After the modification it sat for 10 years before I purchased it and installed and ran it. As soon as I put oil in it and drove it a bit it developed a small drip that is coming from the side cover. I've driven the car for 1400 miles thus far with no slowing or increasing of the leak. I finally decided to fix it and tore into it yesterday and removed the cover. I don't see any apparent sealing surface damage but it looks like a small bit of silicone sealer was used on the o ring. My thinking is that the o ring was compromised by the combination of the silicone and the length of time it sat on the shelf. My question is, besides replacing the o ring are there any tricks I can use to help with the sealing of the cover. Should I use any additional sealant? I'd like this to be a one and done deal. A lot goes into getting access to the cover and getting it off so I'm up for whatever it takes to insure a better seal. Um, besides buying one of the fancy reinforced covers that will make my wallet weep.
Kim
Old 12-11-2021, 07:30 AM
Looks like you know. replace the O ring seal. use no silicone
1986 944 turbo -first car
1997 993 Cab 6 speed-sold
1992 964 C2 turbo
SOLD, 911GT ,CIS, 428 fwhp 450 trq, Carrillo rods, 964 cams, TT retainers,7.5 comp 1.1 bar boost 320 ml black fuel head 009 injectors, 044 pumps, 60-1 T4/T3 dual scroll turbo
Old 12-18-2021, 08:24 AM
