-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/porsche-964-993-technical-forum/)
-   -   Backdating 964 timing chain boxes (http://forums.pelicanparts.com/porsche-964-993-technical-forum/1108952-backdating-964-timing-chain-boxes.html)
Clay Perrine 12-19-2021 08:02 AM
All,
I have a 964 motor in a 914-6 chassis. And I have the typical warped timing chain box issue that is causing a major oil leak. And the cost of replacement magnesium timing chain boxes is outrageous when they are just going to warp and leak again.
I was thinking that maybe the timing chain boxes could be backdated to aluminum boxes off the 3.2 engine, complete with the oil fed tensioners. Has anyone ever done this? I can find used aluminum timing chain boxes online, and I know I would have to buy chain ramps and a tensioner kit, but I think it would be a long term fix for the oil leaks.
Anyone out there know if this can be done?
