993 fog light bulb holder
Looking around for connector(s) for my fog lights on my 993. I've had this 97 993 C4S for many years, it had front euro 993 air scoops with fog lights built in. They use a different connector. The PO had thrown out the old fog lights and turn signal lenses. Found excellent used ones but only one connector for the fog light bulb. I've been able to order the part number ( 813 971 955) but it comes as a stripped shell, no spade connectors, nothing but a tube. I suppose I could find connectors somewhere but the other parts would be hard to find. Any suggestions? Used? Can't seem to locate them, ebay has them in China (over a month away). Would be happy with a used one that worked. Thanks for any suggestions.
Old 03-15-2022, 10:04 AM
The Pet shows several parts but no images... may be part of the internals. Only a couple of them are available. A contact bushing which I assume is the spade connector and a gasket of some sort. I ordered them but doubt I have the complete assembly. Used may be the best way to solve this...
Old 03-15-2022, 11:59 AM
PCA 993 Registry Advocate
Is this what you are looking for?
https://www.amazon.com/813971955-Steering-Servotronic-Pigtail-Connector/dp/B019042GVC
Old 03-19-2022, 09:04 AM
Cobalt's Avatar
The spade connectors are sold individually. You need to look through the PET and find the pins you need and order them individually. Everything Porsche is ALa carte. If I knew earlier I have a half dozen or so of those with pig tales I have saved over the years.
I don't recall what pins theya re but this is what you need to sort through
Anthony PCA affiliate '77 member '83 '90 3.8 RS tribute, 91 C4 converted to C2,'93 964 C2, '93 928 GTS M '94 Turbo 3.6, '15 Boxster GTS M,16 GT4,23 Macan GTS,
Gone worth mentioning '71 E '79 SC, '79 built to '74 3.0 RS tribute (2390 # 270 hp), '80 928 euro 5 speed, '74 2.0l 914, '89 944 S2,'04 Cayenne TT '14 boxster, '14 Cayenne GTS 14 Cayman S, 18 Macan GTS many others
Old 03-22-2022, 05:01 AM
Try VW Part# 813 97 2926 (round connector), and VW # 000 97 9104E for the wire set.
You cut the wire in half, and you’ll have two spade connectors.
Old 03-27-2022, 07:18 AM
