911Obbie's Avatar
92 964 Fuse 19 Brake lights and Cruise Control short somewhere
92 964 Fuse 19 Brake lights and Cruise Control short somewhere.
Was informed by a friend it appeared my brakes lights were not working.
Oddly enough cruise control stopped working as well.
Both run off Fuse 19.
I pulled Fuse 19 as my starting point and it was blown.
Put a new one in.
Next time the ignition was on the fuse blew instantly.
Every time....
Starting point here -
Brake light switch?
Anyone know of cruise control circuit shorts? Control module? Connectorization at the servo?
Thanks for any help, thoughts or similar experiences.
Old 03-18-2022, 07:12 PM
Banned
Put a new one in.
Every time....
Brake light switch?
Interesting
Sent from my TECNO KE5 using Tapatalk
Old 03-19-2022, 06:12 AM
Cobalt's Avatar
I would start with the wiring for the brake lights and more importantly the license plate lights. There is a lot of heat back there and sometimes the insulation now going on 30 years has dried up and creates shorts. Especially when the connectors are played with.
This is what I have found many times with the lighting from the license plate lights on 964's. This was a very clean low mileage car with nearly everything in perfect condition.
Anthony PCA affiliate '77 member '83 '90 3.8 RS tribute, 91 C4 converted to C2,'93 964 C2, '93 928 GTS M '94 Turbo 3.6, '15 Boxster GTS M,16 GT4,23 Macan GTS,
Gone worth mentioning '71 E '79 SC, '79 built to '74 3.0 RS tribute (2390 # 270 hp), '80 928 euro 5 speed, '74 2.0l 914, '89 944 S2,'04 Cayenne TT '14 boxster, '14 Cayenne GTS 14 Cayman S, 18 Macan GTS many others
Old 03-22-2022, 05:30 AM
911Obbie's Avatar
Thanks Cobalt. Will look there first and report back.
Old 03-22-2022, 08:13 PM
