964 C2 - Lowering W/18” Rims
I’m planning to lower the car W/18” BBS rims - I’m running a stk setup at this time. Which coilover kit should I use for street use? What’s the most economical rout?
Bilstein PSS10 ?
Old 05-01-2022, 03:26 PM
The PSS10’s definitely seem to be the favored setup although not the most economical. KW V3 are another option and perhaps a bit more economical although I’ve read some mixed reviews on them and I can’t offer experience as I haven’t been in a car that has them.
My personal setup is the Bilstein Sport Shocks with H&R which does well over smaller bumps and back roads but is a little harsh on the highways with bigger dips and transitions.
CURRENT:
2011 Boxster Spyder, Sport Buckets, MT, Full Leather, PSE, Basalt Black/Black
1990 964 C2, MT, Marine Blue, Silk Grey/Marine Blue
2024 Macan White, Beige / 2010 Cayenne White, Black
PAST: 69 911 Targa, 87 928 MT Marine Blue, 90 928 GT Marine Blue, 90 911 Targa Stone Grey
Old 05-02-2022, 04:46 AM
Thks! Which Bilstein Sport Shocks with H&R springs are you running? P/N would be helpful. Thks!
Old 05-02-2022, 12:27 PM
Mine are the Bilstein B8, I don’t have the exact part numbers as the shocks and springs were done before I got the car. I’ll see if I can find them online.
CURRENT:
Old 05-02-2022, 07:52 PM
For street use I suggest Bilstein B6 or B8 instead of coilover. if you do occasional tracking then it's another story. Gert has B6 XT that can go lower. Or you can check out the new Porsche classic green shock.
Many people runs RoW M030 springs too. H&R is also a good option.
Old 05-04-2022, 03:38 PM
Thanks! Which H&R springs should I get, if want keep my current shocks? The OEM shocks were replaced about year ago.. tying to minimize the cost if I can. Thks
Old 05-04-2022, 04:53 PM
If you’re looking for a lower cost here is one option that will lower the car and also improve handling: https://www.pelicanparts.com/catalog/SuperCat/0834/POR_0834_PRFSUS_pg2.htm
CURRENT:
Old 05-05-2022, 04:53 AM
Thank you!
Old 05-05-2022, 08:23 PM
