Motor Mounts: Wevo, RS vs. OEM
It would be great to get feedback from folks with real world experience using the following motor mounts:
Other details - I'm running the Elephant Racing sport hardness bushings all around, Bilstein B6 w/ OEM springs and the Sleepers short shift kit. I'd like to move to the ROW M030 springs, but they do not appear to be available for the rear 1990 model year. Thank you!
1990 964 C4 |
I had the black pillow Wevo’s on my Targa and I would describe them similar to how you describe the RS mounts. They are firm enough that they are similar to a worn out set of stock mounts as it relates to the vibration and noise. They do however minimize the engine movement which made a significant difference in the corners. The car settled much faster in the corners which made it more stable and predictable.
If reducing NVH is your ultimate goal the stock mounts are your best bet. I believe the 993 mounts may also be an option and cost a little less.
CURRENT: 2011 Boxster Spyder, Sport Buckets, MT, Full Leather, PSE, Basalt Black/Black 1990 964 C2, MT, Marine Blue, Silk Grey/Marine Blue 2024 Macan White, Beige / 2010 Cayenne White, Black PAST: 69 911 Targa, 87 928 MT Marine Blue, 90 928 GT Marine Blue, 90 911 Targa Stone Grey |
1990 964 C4 |
Good info here. Following for later use
I ended up going with the 993 C4 mounts in my 964 C4. Car feels great, much smoother than the RS mounts. The whole car isn't shaking at stoplights anymore. The 996 GT3 mounts that looked to be half the price were an old part number. The new part number are more expensive than the 993 motor mounts. I expect to be doing a longer, multi-day trip in a couple of weeks, so that will be the true test.*
1990 964 C4 |
