-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/porsche-964-993-technical-forum/)
-   -   Convert g64 trans to RWD (http://forums.pelicanparts.com/porsche-964-993-technical-forum/1152209-convert-g64-trans-rwd.html)
GTS 22 12-16-2023 11:04 AM
We have been working on a C2 project and would like to use the G64 transmission we have. Has anyone completed converting a G64 trans to RWD? I know the internals of G64 and the G50 are different but is there some trick or kit that can be purchased to make the conversion to RWD? The car is a C2 so the removal of all of the drive line tube shifter fabrication and front axles etc is not an issue
Any help?
Bill Verburg 12-17-2023 09:26 AM
Any help?
As you know the issue is the concentric output shafts, blue shaft to rear yellow to front
http://forums.pelicanparts.com/uploa...1702833704.jpgand planetary gear set connecting them
http://forums.pelicanparts.com/uploa...1702833806.jpg
Shown here are the differences, stock g50 parts are green
http://forums.pelicanparts.com/uploa...1702833857.jpg
You could remove the planetary gear assembly and weld the shafts together
or replace all the internal g64 parts
Matt Monson 12-26-2023 07:54 AM
There is a pretty detailed thread on Rennlist on how to do this. It’s not easy.
parkertseng 02-05-2024 07:21 PM
Do you have the link from Rennlist?
