-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/porsche-964-993-technical-forum/)
-   -   '89 C4: Front Differential Interlock Problems?? (http://forums.pelicanparts.com/porsche-964-993-technical-forum/116100-89-c4-front-differential-interlock-problems.html)
sms1305 06-23-2003 11:38 AM
My '89 C4 has 42500 miles on it. Today, on my way to work I had trouble after about 20 minutes of highway driving. It started to surge, hesitate, and buck - the alarm panel kept lighting up with the central alarm (!), ABS warning and the interlock indicators. After a minute or so (after slowing down and checking it out), the car settled down again. It felt like the front diff was grabbing and releasing in a pulse-like, jerky manner, and I thought I could hear the sound of solenoids engaging and disengaging. I don't know if it is related, but my radio wouldn't stay on during this time, either... Any known or easy fixes or do I need to go straight to the mechanic? Thanks.
91C2wrencher 06-23-2003 12:50 PM
Sounds electrical. Maybe a bad battery or most likely a, failing alternator/ voltage regulator. do a search here for old threads.
Type961 06-30-2003 09:06 AM
Hi,
I also had the same kind of problems.
I can confirm that after changing the battery everything was ok ;)
Luc.
