-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/porsche-964-993-technical-forum/)
-   -   964 - Valve guide wear limits / piston ring gap specs (http://forums.pelicanparts.com/porsche-964-993-technical-forum/1172317-964-valve-guide-wear-limits-piston-ring-gap-specs.html)
Porscheke 01-06-2025 07:13 AM
Hello
Does anyone here have the wear limits for the intake and exhaust valve guides for a Porsche 964?
I've measured one exhaust valve (visually the worst one that was full off residual oils)
Valve popped out 1 cm, I measure ± 0.2mm if I wiggle it up and down.
I can't find above requested wear limits in the manuals?
Regarding the pistons (this is what I found in an earlier conversation);
What should piston ring gaps be on a Porsche 964?
Top compression ring: 0.15mm??
2nd compression ring: 0.3mm??
Oil seal ring: between 0.15 - 0.3 mm??
Are these numbers correct?
prschmn 01-06-2025 08:02 AM
Your guide measurement doesn't sound too bad but you're probably going to have a hard time findiing rings that won't already have a much larger gap.
Porscheke 01-06-2025 08:11 AM
I have read somwhere that guide wear limit is 0,15mm.....but I can't find this number back in the manuals that I have.
Also I don't now if this limit is for inlet and exhaust
Regarding the piston rings, are you telling that new mahle rings already have a bigger tolerance then that I mention?
prschmn 01-06-2025 08:19 AM
Can't tell you what Porsche says but always a bit more for exhaust. I hone guides to about
.03 intake and .05 exhaust. And yes the new rings are likely going to have much bigger gaps.
