Turboman's Avatar
Send a message via Skype™ to Turboman
Porsche 964 intake manifold
One simple question, to the knowledge participants.
Early 964s have a aluminum intake manifold. (1989/1990)
Late 964s have a plastic intake manifold (1991/1994)
Is there a performance advantage or a cost savings move?
Appreciate your comments
Francisco 1970 914-6 1991 964 Cabrio.
Old 02-24-2025, 04:26 AM
Some older Porsche documentations suggests a slight improvement in performance and weight savings. It doesn’t mention cost savings but it’s pretty hard to argue that wasn’t part of their goal.
CURRENT:
2011 Boxster Spyder, Sport Buckets, MT, Full Leather, PSE, Basalt Black/Black
1990 964 C2, MT, Marine Blue, Silk Grey/Marine Blue
2024 Macan White, Beige / 2010 Cayenne White, Black
PAST: 69 911 Targa, 87 928 MT Marine Blue, 90 928 GT Marine Blue, 90 911 Targa Stone Grey
Old 02-25-2025, 07:06 PM
One 964 I had came with Al intake manifold and the other plastic. Plastic easier to keep clean.
I imagine it was less about performance improvement over a cost saving for sure. Any performance improvement would be negligible.
___________________
Current:
964 C4 - Light RS additions and modifications
968 Sport - M030 suspension with adj Koni Setup
Mk 5 Golf GTi - As good as it gets
Old 02-26-2025, 07:59 AM
Banned
The plastic manifolds are generally more durable in terms of heat resistance and less prone to cracking, which can be an advantage in the long run.
Old 03-01-2025, 04:13 PM
Cobalt's Avatar
The aluminum intake came on the earlier ringless engines. The cost for the AL casting I have little doubt was far greater than a plastic intake. Not a chance that the AL casting would crack and heat is not an issue. They also eliminated the magnesium center casting for a plastic one so I suspect it was mostly cost as the Mag casting was probably more than both AL intakes back in 1990's. At the same time the internal surface finish of the AL casting was not great with additional surface roughness that created turbulence so it is possible it had something to do with fuel economy and performance. Although my bet is on cost.
They also switched from Mag valve covers to aluminum ones about that time. I also suspect that was a cost driven change.
Anthony PCA affiliate '77 member '83 '90 3.8 RS tribute, 91 C4 converted to C2,'93 964 C2, '93 928 GTS M '94 Turbo 3.6, '15 Boxster GTS M,16 GT4,23 Macan GTS,
Gone worth mentioning '71 E '79 SC, '79 built to '74 3.0 RS tribute (2390 # 270 hp), '80 928 euro 5 speed, '74 2.0l 914, '89 944 S2,'04 Cayenne TT '14 boxster, '14 Cayenne GTS 14 Cayman S, 18 Macan GTS many others
Old 03-04-2025, 04:45 AM
