-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/porsche-964-993-technical-forum/)
-   -   Tachometer not working when lights turned on (http://forums.pelicanparts.com/porsche-964-993-technical-forum/1178640-tachometer-not-working-when-lights-turned.html)
Major Kong 06-03-2025 03:54 PM
I have a 1990 Porsche 964 Cabriolet C2. When driving in daylight hours, the tach operates normally. When I turn on the parking lights, running lights or headlamps, the tach immediately shuts off & drops to zero. The instrument is still illuminated, but the tach stops working. If I turn off the lights & restart the car, everything is normal. Any help or suggestion would be appreciated.
Swann 06-09-2025 05:08 PM
That definitely sounds like an electrical issue most likely a grounding or wiring problem. The fact that the tach dies only when the lights are on points to a shared ground or a voltage drop affecting the tach signal.
