Party Member
viejopatron's Avatar
Cracks in Fan Housing
Hi,
The car is a 1995 993 C2 Tiptronic (M64.08 Engine) with 198,000 Miles. I removed the Fan Housing/Alternator/Impeller (Fan) Assembly to replace the Fan (missing blade) and found cracks in the Housing. See photo.
The cracks are located outside the stud circle; the bigger cracks look like they may be the result of an impact and the smaller cracks are circumferential, at the base of the locating lip for the plastic Hub Extension. One stud boss is cracked. None appear new.
Now let's put on our MRB (Material Review Board) hats. Do I ...
A - Accept and Use-as-Is?
B - Repair using Crack Repair Compound or ????
C - Return. Not an Option
D - Scrap and Replace. Least preferred and most expensive.
Gary
71 911T Miss Demeanor / 2013 Audi Q5 Hundeführer / 1995 993 Miss Adventure
Old 06-09-2025, 05:42 AM
Cobalt's Avatar
Part needs to be media blasted and then what remains will tell you the answer.
Looks like one of the nuts holding the alternator in place was not torqued down properly causing it to vibrate and crack under load. I suspect after media blasting it might be usable but only one way to find out.
GL
Anthony PCA affiliate '77 member '83 '90 3.8 RS tribute, 91 C4 converted to C2,'93 964 C2, '93 928 GTS M '94 Turbo 3.6, '15 Boxster GTS M,16 GT4,23 Macan GTS,
Gone worth mentioning '71 E '79 SC, '79 built to '74 3.0 RS tribute (2390 # 270 hp), '80 928 euro 5 speed, '74 2.0l 914, '89 944 S2,'04 Cayenne TT '14 boxster, '14 Cayenne GTS 14 Cayman S, 18 Macan GTS many others
Old 06-13-2025, 05:28 AM
