Picked up a 94 RS America
The short version is - I bought and sold this car 4 years ago when the timing just wasn't right - and I was able to buy it back (at a premium) last week. Really happy to get it back. It's pretty well sorted for 138k miles. It's had a 8/10 respray with pretty much every rubber piece (except tail trim..get to that in a sec) replaced. Previous owner had the car since 2008 and apparently it was painted prior to his ownership - he was told it was sun faded, which is believable because the seats were faded as well (owner who had the car for the last 4 years DID replace the seats with mint originals, so..whew!).
Anyway, for the tail trim - does anyone know the exact difference between the "original supplier) version and the actual porsche version? Does the non porsche one still have the crest any everything? The price difference is substatial...AND I'm sure many who are offering an original piece out there are actually selling you the repro. Original supplier: https://www.pelicanparts.com/More_Info/91151209100.htm?pn=911-512-091-00-INT and another one that is probably carrera but hard to tell - guess it's the same as RSA? https://einmaligparts.3dcartstores.com/Polyuret-Rim-For-Spoiler-Satin-Black1_p_149272.html ![]() |
it's beautiful
Always learning. www.aircooledporsches.com.au See me bumble my way through my first EFI and TURBO conversion! https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP |
Jeff congrats, it’s a beautiful RSA! It looks to be in great shape already so only the typical 964 refresh and she’s good to go.
I haven’t looked too closely at the RSA wing, does the rubber trim have a Porsche logo on it? If yes I’d bet the repo version will not have any type of Porsche markings on it. If the original doesn’t have markings the primary question is if the fitment is as good on the repo although if its OEM then it likely is. Post up some more pics when you get a chance….
CURRENT: 2011 Boxster Spyder, Sport Buckets, MT, Full Leather, PSE, Basalt Black/Black 1990 964 C2, MT, Marine Blue, Silk Grey/Marine Blue 2024 Macan White, Beige / 2010 Cayenne White, Black PAST: 69 911 Targa, 87 928 MT Marine Blue, 90 928 GT Marine Blue, 90 911 Targa Stone Grey |
Administrator
WOW! Congrats, she's beautiful. And quite frankly, silver is my favorite color on a car. Now, the real question is.. will you keep her this time?
If you need help with the tail trim you can give our salespeople a shout and they should be able to help you track down the right part #. |
She really does look like a great example and the fact that you know its history for the last two owners is a plus….. ![]() Get out and enjoy the car. The more you experience it the more you’ll continue to fall in love with the platform and the engine. They do need some updating and upgrading as you already know but that’s part of the fun….and what makes it your own. Out of curiosity are you going to sell the blue one or slowly rebuild it?
It's in really good shape for the miles - amazing, really. I intend to do some deep cleaning and normal improvement/restoration of some areas and will also do some modifications to suspension/wheels..really just things that can be reversed. The blue one is staying at this point. I'm looking forward to the build still - just wanted an aircooled to drive in the meantime..it will serve as a reference model and a way to set my expectations of the new build ![]() ![]() |
This was common on all the wings dating back to the original whale tail.
Anthony PCA affiliate '77 member '83 '90 3.8 RS tribute, 91 C4 converted to C2,'93 964 C2, '93 928 GTS M '94 Turbo 3.6, '15 Boxster GTS M,16 GT4,23 Macan GTS, Gone worth mentioning '71 E '79 SC, '79 built to '74 3.0 RS tribute (2390 # 270 hp), '80 928 euro 5 speed, '74 2.0l 914, '89 944 S2,'04 Cayenne TT '14 boxster, '14 Cayenne GTS 14 Cayman S, 18 Macan GTS many others |
Very nice! being a '94, does it have back seats?
Good times! I am really on the fence with the car, about changing things. I know 100% that I will not do anything that cant be reversed... but I really want to OEM+ some parts and modernize others. I can see a set of E88s, PSS10s, big reds (or blacks), RS uprights and MAYBE a regear happening. Still pondering. |
I say enjoy. I have done a lot of modifications to all my cars some are easily returnable to stock others not so much. Even my turbo has some mods but I have all the original parts and can easily convert it back and enough spares to build a few. Preserving the seats is a smart Idea but wrap them up nicely and keep them in a climate controlled room. Those bolsters will wear eventually and someday you will probably appreciate it.
3 years later...I've done some mods
looks amazing. glad you were able to get her back.
Nice ! Did you use the RS uprights or stock 993 ? I see the RS tie rod set , which ABS wheel were you able to use ? Thanks Im about to go through this with my C4 converted to 3.8 , 6 spd mnl , manual steering and RWD swap , everything is about in but the rack and the uprights LOL , Bert
GT2 RS 3.2 RSCS 3.8 R 2.5 Twin Plug |
I did something else non-conventional. I modified the 964 longitudinal to push the control arm out by 8mm. I did this because 993 uprights (rs and non rs) have a slightly different balljoint location, causing the track to be reduced by 8mm when used on a 964. Otherwise, your options are 964long and 993 upright = -8mm. 993 long and 993 upright = +8mm. This situation is why you see most people struggle to get enough camber after a 993 upright swap onto a 964. Happy to help however I can. |
