Shift to reverse 90 C2
Help! My brother borrowed my C2 while I was out of town. Upon my return I found that it would not shift into reverse. The stick won't push down and slide forward. It seems to be binding on something. All of the other gears work and it runs fine. I can't even get it to shift with the engine shut off. It just won't slide into reverse. Any suggestions?? Help. My brother claims it worked fine when he had it. Thanks, please help, :( :( :(
I hope you get it fixed or you'll have to replace the taransmission. On the other hand, you probably can't fix your brother and you may think about replacing him too.
| All times are GMT -8. The time now is 08:46 PM. |
