Are the valves on a '92 C2 Turbo manually adjustable ?
Sounds like a foolish question but someone indicated these 3.3 motors did not need valve adjustments as they are hydraulic(??)?
Owning a '79 3.3 I understand the need to have the valves properly adjusted. Will the valves on the C2 Turbo be adjusted the same way ? Thanks.
1969 911E Albert Blue 1970 911E Iris Blue 1970 911T Signal Orange 1972 911T Gold Metallic 1981 930 Arctic Blue 1981 930 BB Auto(on ship) 1987 930 Cassis Red Met 1996 993TT Black 2007 997TT Cobalt 2017 991 Turbo Cab |
Yes, they are manual adjusters. Only it takes a lot longer due to the extra pipework.
From November 2012; Precision Porsche Specialist Sussex UK, +44 (0)1825-721-205 2001-2012 Gerber Motorsport Inc. 206-352-6911 07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red 08.16.09 1999 Kawasaki ZRX1100. Green. |
Thanks a bunch.
I can add in that I couldn't really do the top (intake) valve adjustment without lowering the motor down a bit.
92 C2 Turbo Coupe, Gran Prix White Tial 46mm .5bar, k27 7200 11/11 LF Welded in Roll Bar, Sparco Pro2000 seats, RS Carpet Set |
