Central Warning Light
After the recent purchase of my 91' C2 964 I noticed that the Cental Warning light indicator on the dash does not light when the vehicle is started. I did notice that the warning cancel button on the console is lit and if I reset it it will go out. The car seems to be running fine but I am concerned if there is a hidden problem that I missed. Any help would be great. Thanks in advance
Old 11-13-2003, 06:35 AM
Could be the P.O. removed a warning bulb from one of the dash gauges. I had to remove my air bag bulb because I inadvertently started my car with the crash sensor disconnected while doing some work on it. The warning light was a nuisance and I pulled it until I get a chance to have the dealer clear my fault code. So pull all your gauges and look for a burnt or missing bulb,or get the the fault codes checked at the dealer. Also check Rennlist 964 forum for the check engine light method to pull fault codes.
1990 C4 Cabrio
1983 911SC (RIP)
1997 Expedition EB
2004 EXPLORER ( Momma's Car)
Zink Z-12 FV ( sold )
2005 Cub Cadet 1046
Old 11-13-2003, 09:08 AM
Thanks for the info I will check this out
Old 11-13-2003, 09:19 AM
