964 engine dimensions
I am looking for some engine dimensions of a 964 Porsche engine... obvious things like stroke and bore size are often mentioned but things like conrod length etc. are not as common.
The dimensions I'm after are: - (1) Connectingrod length (heart to heart) and big-end bore size (2) - (A) Engine case width (where the cylinders mate with the engine case) - (B) Size of the bore in the case accepting the cylinders - (C) Bore spacing of the cylinders (heart to heart of the cylinders next to each other) - Valve diameters of a N/A engine (inlet and outlet) Picture to illustrate the requested dimensions: http://members.home.nl/r.vd.meulen/964.jpg I only found one statement for the conrod wich said it was 5" (127mm) The rest I haven't seen anywhere... Anyone got any answers to these dimensions? |
/\ bump /\
Okay, so how about size (A), Case width from left to right where the cylinders enter the case (mate...) Please, I really need it for an engine project... |
In older engines the B dimension was 97 mm (up to 90 mm cylinder bore/2.7 l - when stud pattern was 80 x 80 mm). I don't know what is that dimension in newer engines with 86 x 86 mm stud pattern
| All times are GMT -8. The time now is 06:14 PM. |
