LonL's Avatar
Climate Control
Hi,
I have a 91 964 with a blower issue. The AC fan blower does not operate. I am wondering if it is the fan switch in the climate control panel, it has almost zero resistance when turned. I feel no detents at all when turning the switch. Since this is my first Porsche I have nothing to compare it to. I know on most cars you feel a click each time you turn the knob.
Thanks,
Lon
Old 02-17-2004, 08:51 AM
LonL's Avatar
A little follow up on this. The two are not related, it was a fuse that was blown in radio, however I still need some guidance on the fan issue. I get NO fan at all, the rear blower fan does not work ( checked all fuses front and rear) nor does the 2 front fans. I checked voltage at the plug to the rear motor and got .3 volts regardless of fan speed setting. does this mean anything to anyone? I am thinking the contol module is faulty.
Lon
1991 964 Targa
Old 02-19-2004, 09:57 AM
Try posting this question on rennlist in the 964 forum. There is a lot more help on 964's there.
Old 02-20-2004, 05:37 PM
LonL's Avatar
Thanks, I will try that
1991 964 Targa
Old 02-20-2004, 06:56 PM
maxnine11's Avatar
i see that Randal G replied to your post on rennlist. He really seems to know the workings of the 964 climate control!! do a search using his user name there; or search all of his posts, and you will find a lot of good info.
good luck,
max
max
Old 02-21-2004, 11:10 AM
LonL's Avatar
Well, I feel a little dumb. The problem is solved. The number 28 fuse was missing. all is good now
Lon
1991 964 Targa
Old 02-21-2004, 03:19 PM
maxnine11's Avatar
Cool probably the cheapest part on your car!! ( save for the air in your tires )
max
max
Old 02-21-2004, 06:57 PM
