zcab911's Avatar
OEM Audio Amp C2 Cab????
I am replacing my outdated 1992 C2 Cab Stuttgart Blaupunkt Cassette unit with a newer Kenwood MP3 model. In doing so, I knoticed that there are three connectors: One for power (duh), one for speakers (which was not connected), and a third marked "preamp", which was connected. I never believed that there is a audio amp in the car because it sounded so bad, but I would like to know if there might be one? I have looked online for this and there is a option code marked 494 implying that there might be one somewhere (but where???) in the car. Any ideas?
Old 03-08-2004, 08:29 PM
zcab, The factory location for the amp is under the passenger seat. Just move your seat all the way forward and it should be visible. It's not very powerful and most people replace them when upgrading. Regards, Roy
1991 C2 Cabriolet Tip, 1994 Speedster
Old 03-09-2004, 03:42 AM
zcab911's Avatar
Thanks. I found the model number online last night and the specs. It is a Blaupunkt BQB-80.
Maximum power output
4 x 20 Watts into 4 ohms
Nominal power output
4 x 18 Watts RMS into 4 ohms
Frequency response
-1.5dB from 30 Hz - 16,000 Hz
Distortion
<0.1% typical @ 4W / 1,000 Hz
Channel Separation
>50 dB
Signal to Noise Ratio
<1mV
Amplification
8.5 dB, (47 ohms input) @ f=1,000 Hz
Speaker impedance
4 ohm
Power supply voltage
DC 12V (11-14V), negative ground
Power Consumption
Idle = 500mA
6.00A for 10W / channel
It was dark last night so I couldn't find it in the car. Any recommendations as to a good aftermarket solution?
Old 03-09-2004, 06:39 AM
zcab911's Avatar
Found it. Measures 4"x7"x2". Teeny-Tiny. Any suggestions for aftermarket that might fit in the same area?
Old 03-09-2004, 07:59 AM
Contact this place...
http://www.caraudioinnovations.com/
'?? 964 - still shoppnig
'91 3.3 turbo - gone = (
Old 03-17-2004, 08:05 PM
