-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/porsche-964-993-technical-forum/)
-   -   Does this look like the LUK update? (http://forums.pelicanparts.com/porsche-964-993-technical-forum/171830-does-look-like-luk-update.html)
LPDandrea 07-10-2004 11:25 PM
Can anybody tell if this is the updated flywheel? LUK is stamped in the hub as you can see in the photo but it is dual-mass. I was under the impression (possibly mistaken) that only the Freudenburg is dual-mass. What's the straight scoop?
thanks, this board is cool:cool: http://forums.pelicanparts.com/uploa...1089527077.jpg
Britwrench 07-11-2004 10:36 AM
That's a LUK, the Freudenberg one has a thin steel washer under the bolts.
Make sure you replace ALL of the worn and suspect parts when re-assembling and only use the Porsche grease.
john_colasante 07-12-2004 08:25 AM
All 964 and 993 use dual-mass flywheel. Exception '89 Carrera 4 and RS/Cup models.
