Question Sunroof Blues
Does anyone know what the name or part number is for the clips that the sunroof rides on that attach to the wind deflector on a coupe. The wind deflector is spring loaded and the driver side clip cracked where it attaches to the wind deflector. When I close the sunroof the wind deflector does lay flat as the sunroof closes and hangs up on the lip of the sunroof. Any help would be great.
Old 05-05-2005, 01:23 PM
jbh jbh is offline
If you are refering to Part 25 in the diagram below, the part number is 911 564 123 00. It is called a clip.
If that is not the part, let me know which one and I'll look it up
I recently broke the hinge (Part 23) which is part number 911 564 127 00
Old 05-09-2005, 08:51 PM
JBH thanks for the diagram. The part that broke is part 23. Do you happen to have that part number? Once again thanks foryour input. All the folks on this board are great.
Old 05-10-2005, 05:10 AM
Same as the one that broke on mine: 911 564 127 00
Old 05-10-2005, 06:58 AM
Thanks for all your help.
Old 05-10-2005, 10:17 AM
Got the part which cost $3.80 and took about 5 minutes to install. Thanks for the help
Old 05-20-2005, 11:13 AM
