-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/porsche-964-993-technical-forum/)
-   -   driver side heated seat problem (http://forums.pelicanparts.com/porsche-964-993-technical-forum/191914-driver-side-heated-seat-problem.html)
Buck toenges 11-11-2004 05:34 PM
My driver side seat heat doesnt heat. The passenger side does. Any tips on checking the seat out? Too poor to move to Fla. for winter. '95 c4 cab.
SmileWavy
project935 11-12-2004 04:03 AM
Check the wiring, connectors, and fuses - should be easy stuff to do w/o removing the seat.
Pull and check the switch with a meter - they go bad.
If those checks don't fix it, then the seat probably needs to be removed and the upolstery pulled to check out the heat element.
