Rear Spoiler Warning Light
While driving, the Central Warning Light, Along with the Rear Spoiler Warning light comes on whenever I go over 50mph, and doesen't turn off until I stop. I know the wing is going up, because i can hear it go down after i stop.
Any suggestions?
Thanks for any help.
Old 11-03-2002, 08:23 PM
PRO Motorsports
Tyson Schmidt's Avatar
Check the "up" microswitch. Make sure that when it is closed, there is continuity through the two wires.
Also, you could remove the control module from under the passengers side dash, remove the cover, and clean the contact points of the tw0 relays with electrical contact cleaner. This fix is more for tails that don't raise.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 11-05-2002, 08:17 PM
1
Thanks alot, the set screw on the micro switch just needed to be adjusted.
thanks again, danny
Old 11-06-2002, 03:05 PM
Cool
i have a 996 1998 convertable with same prop ! can you tell me were control box is please ?
Thanks darren
Old 11-13-2004, 04:12 PM
maxnine11's Avatar
Isn't a 1998 model a 993?? ( even on your side of the pond )
IIRC, a 996 doesn't have a seperate control module for the spoiler, but is controlled by one of the main computers in the car.
If it is a 993 you have, the spoiler module is located up under the dash near the glove box. (about 2" x 3" x 1" thick )
max
max
Old 11-13-2004, 05:45 PM
Tom W's Avatar
The control for a 993 is in the same place as the 964, the passenger footwell (about the middle and slightly below the glove box behind the carpet). It a small rectangular module (maybe 1.5x1.5x2.5 inches).
Tom
SL63 AMG Daily Driver
'92 964 now a GT3R/GTL toy for track fun (Tom's Turtle)
Old 11-15-2004, 08:11 AM
hi yes mine is a 996 i have changed spoiler motor and gearing from a car i no works spoiler goes up at 50 mph but does,t return when i stop and warning light is on !! any glues please
thanks darren
Old 11-30-2004, 12:00 PM
