Where's the Leak?
94 C2...l have a lead getting worse right around the oil tank. At first I thought the drain plug was loose....no. I don't have my jack w/me now so I can't see exactly what the drama is. When you get a leak around the oil tank is it usually a hose issue?
Old 11-28-2004, 06:52 PM
colo964's Avatar
I've had some hoses cut through by the clamps. There are 3 or so rubber hoses with clamps and some hard pipes. Also, the pop off valve is on the top of the tank. Did you overfill it?
Old 11-28-2004, 08:31 PM
Don Haney's Avatar
My oil line leak was from the oil filter consol to the thermostat stat, leaking at the joint where the material/steel line come together. The oil ran down the line and looked like the tank was leaking.
The only way to tell is to clean the area and drive it a short distance and inspect.
Good Luck, its really tight and a B*tch to work on...
Don
Don Haney
don@pelicanparts.com
888-280-7799 Ext 305
1991 C2 Tip - Sold
Old 11-30-2004, 09:23 AM
Don Haney's Avatar
btw-If you over fill the tank, you'll have injection problems first...
The oil will back up into the intake runners
Don
Don Haney
1991 C2 Tip - Sold
Old 11-30-2004, 09:24 AM
colo964's Avatar
Wouldn't an overfill will affect your plugs before your injectors? Seems like the breather hose will breathe a lot of oil drops into the intake or suck it from the oil tank and coat the plugs that way.
Old 12-02-2004, 08:22 PM
