964 H4 headlight question
Hello,
I’ve a question relating to 964 H4 headlight:
I noticed that when I turn on high beam low beam keep switched on too.
Is it normal? Usually with H4 lamps when high beam are switched on low beam are switched off.
I have a second question: how does the height regulations work? It is a pneumatic system operated by?
Old 09-26-2014, 12:35 AM
Can someone check in his 964? Thanks.
Old 09-29-2014, 12:41 AM
I have the answer. In euro 964s wheen high beams are on low beams are on too.
Old 10-31-2014, 02:18 AM
