wastintime's Avatar
Send a message via AIM to wastintime
964 Door Panel Removal ?
How do you remove the locking knob on a 964 door panel so that you can remove the panel? I've prised the cap off, and unscrewed the screw. I can't see anything else to do, but the panel won't come off. I don't want to pull too hard either incase there is something I haven't removed. Lol, what am I mising?
Old 09-14-2003, 08:10 PM
In addition to the knob, take off the following:
Door pocket
Door handle
Top door trim
The door panel is held on with plastic snaps. It shouldn't be too hard to remove.
John
1997 993
2012 991
Old 09-15-2003, 08:42 AM
I've been searching the forum for how to remove just the pocket. I've got the screws from along the bottom removed; I've got the screws from the front and back or the pocket removed; I';ve got the screw from the bracket inside the pocket, where it attaches to the door handle, removed.
It seems to being held on by the handle somehow. Any suggestions?
-Rf.
Old 04-08-2005, 04:16 PM
colo964's Avatar
There are 2 allen bolts in the handle area that you need to undo (5 or 6mm). Also the speaker crossover sits between the open pocket and the covered one and is a pretty tight fit.
Old 04-08-2005, 04:28 PM
That (2 allen bolts) was the trick. Thanks
Old 04-09-2005, 06:52 PM
