Diverwes's Avatar
Wastgate ?
Big ? the tube on top of the wastgate gets screwed into top of gate and goes into engine comp but its hooked to nothing is this right it just goes in and hooks down thats it.
1991 Turbo Polar Silver.
415 HP of pure FUN
Old 05-12-2005, 05:50 PM
Eli at Pelican Parts's Avatar
Are you speaking of the release end? Have any photos?
Old 05-13-2005, 10:46 AM
Yes, that's how it should be. It's a vent tube, and the reason it's going into the engine compartment is just to keep dirt and moisture out of it.
Old 05-13-2005, 04:50 PM
Diverwes's Avatar
Question
Ok Thanks now anyone know where i can get the gasket that goes between the alum top and the stainless bottom. I guess you are not suppose to take off the 3 nuts for that.
Live and learn.
415 HP of pure FUN
Old 05-15-2005, 07:37 PM
350HP930's Avatar
Yes, that tube from the top of the wastegate is a vent. Unless you add an aftermarket boost controller it should just go somewhere where it can breath well but not injest any water.
As far as that little gasket goes, I assume you might be able to order it from our host or the dealer but when I disassembled and rebuilt my wastegate mine was still relatively intact so I just used a little high temp silicon to mend what little damage occured and used it again.
Old 05-16-2005, 05:22 PM
Diverwes's Avatar
Well untill i get parts to rebuild old wastgate I bought a new one.
415 HP of pure FUN
Old 05-17-2005, 03:29 PM
Looks good! I hope that's high-temp rated hose on the actuator line!
Old 05-17-2005, 04:30 PM
That's what you call a diamond in the rough.....
Old 05-17-2005, 04:32 PM
