Aviation gas
Hi,
I have access to airplane gasoline, I think its 105+octane.
My car has a rennsport chip, that need 95+octane.
Here in Brazil gasoline in the pump has 25% alcohol. The airplane gas is 100% pure.
I am planning in starting with a 50% pump 50% airplane mixture.
Will the high octane do good or bad for my motor?
Old 05-30-2005, 07:19 AM
most avgas, (80 or 100 LL) is or was when i used to be around it was low lead. lead, which was the lubrication of the fuel. i ran it in a 70 nova while working at a f.b.o in the 70's.it eventually burnt the valves out of it. it might be ok using a mixture of gas though. you use to be able to purchase lead additives. sure runs good when its a straight 100LL though.
p.s. i believe in 86 all cars were built to run on non leaded fuels. so running avgas with lead now with the new design seats and valves, etc, would probably be detrimental. just my 2 cents
Old 05-30-2005, 07:32 AM
I know people who have done this and wished the had not.
SW
Old 05-31-2005, 03:03 PM
grmnxtc's Avatar
DO NOT *REPEAT* NOT USE ANY FUEL WITH LEAD IN IT, IN A VEHICLE FITTED WITH A CATALYST!!!
It will kill your catalyst in a matter of minutes/hours... and work out to be a VERY expensive fix....
High octane is good... but high octane with ANY amount of Lead is a BIG NO_NO!!!!
Clive.
Clive.
GRMN XTC is a '95 993 Cab.
Guards Red/Cashmere
Old 05-31-2005, 03:57 PM
Thatīs what I thought about lead, specialy because the sticker says "unleaded fuel only". I beleive its unleaded, in Brazil all fuels has to be free of lead ( at least for cars ). I will check.
They told me its rated 110-115 octane.
My concerns are that here gasoline must be mixed with alcohol ( 25% ), and this makes my car run lean, witch is bad. So doing a 50/50 mixture will reduce this problem.
Old 06-01-2005, 04:37 AM
Ok I just received the reply to my email to Petrobras. The avi gas is 100/130 octaine and has tetraetila lead aditive.
The lead is bad for the cat, but it only looses it emissions properties or will it damage the motor or performance?
Old 06-08-2005, 10:44 AM
kang's Avatar
I'm not sure, but I think it can evntually clog or gum up the cat, restricting its ability to pass gas. Forgive the pun.
Downshift
Old 06-08-2005, 12:14 PM
Kang,
is there any problem in taking the cat out of the car?
I have no emission issues here in Brazil.
Old 06-08-2005, 12:33 PM
no cat
I ran mine for years without a cat. I had a Fabspeed bypass which worked well.
SW
Old 06-08-2005, 01:16 PM
and does it have any hp bennefit?
Old 06-08-2005, 01:22 PM
maybe a little, I was running pump gas not avgas. I did it for the sound.
SW
Old 06-08-2005, 01:25 PM
kang's Avatar
I've heard there is actually a performance hit by removing the cat. The engine needs a certain amount of backpressure. Without it, you lose low end torque.
Downshift
Old 06-08-2005, 02:19 PM
