CBRacerX's Avatar
993 Cabriolet Top Issues
Greetings,
My 96 993 cabriolet has a top that is stating to be prone to misbehaving. The symptom is a refusal to go down when up, and vice versa. I can hear a relay click in the trunk when I press the top activation switch, but there is no action from the top motors. Wait a few minutes (or longer) and the top will behave normally. Sometimes turning the ignition on or off helps, but not usually. Sometimes the car needs to be driven before this works again. When it works, all is fine.
I think this is an intermittent connection on the power bus to the top relay, but that is only a guess. Anyone have a similar experience that they could solve?
Cheers,
Chris
Old 08-01-2005, 06:14 PM
hallo Chris
Check the emergency Brake switch , it is behind the lever in the Middle console under the Cassete holder . When the Top not moves ,see if the warninglight is on .
I had a few Times the wiringharness in the Top broken , than the relais is not getting the info from the locks and it wont move .
The Top-relais itself is under the Dashboard in the Drivers Footwell .
It is a black Box with 4 bigger Plug-ins . It is hidden under the Central informer .
Harald
Old 08-03-2005, 02:21 PM
CBRacerX's Avatar
Thanks Harald, I will look at the wiring under the drivers side in detail~!
Chris
https://dergarage.com
‘11 987.2 CS, '01 986S, '11 958S, '24 R1T, '87 Defender V8
Old 08-03-2005, 03:09 PM
more common is the brakeswitch and the harness in the Top .
harald
Old 08-03-2005, 03:23 PM
Don't forget the recall for 95-98 993 Cabs. Call your official dealer with the VIN.
It's mainly to fix the header rail motors.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 08-04-2005, 05:08 PM
