-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/porsche-964-993-technical-forum/)
-   -   CDR 210 radio not working - help! (http://forums.pelicanparts.com/porsche-964-993-technical-forum/234773-cdr-210-radio-not-working-help.html)
mack 08-06-2005 05:07 PM
Had to jump my 97 993 and radio stopped working. When it is put on, the word CODE is displayed (it does NOT flash), but then the radio clicks off a few seconds later. Not enough time to even enter a code, and as mentioned, the word CODE does not flash as it is suppose to during the resetting mode. I called SW Stereo who advertises in PANORAMA and he felt that jump starting the car probably fritzed the radio. He sent me a refurbished unit, installed it today, and the exact same symptoms continue. I can hear the amplifier under the right seat clicking on and off - and again - the radio stays powered for no more than a few seconds before shutting itself off again. The good news is that the problem does not appear then to be the radio - could the amplifier be causing this problem?? The #38 radio fuse is fine. Thanks!
AFJuvat 08-07-2005 07:19 AM
The amp is most likely toast.
Sorry
AFJuvat
mack 08-08-2005 06:14 PM
CDR 210 problem fixed
FYI to all of those who viewed this posting. The problem turned out to be the trunk CD changer - as a last resort, I unplugged it and the radio stayed on, code entered, and problem fixed. CD changer was somehow damaged during the jump start and corrupted the radio until it was disconnected.
