Can a 1990 964 C4 use these wheels ?
99' Porsche Boxster OEM 17 inch alloy wheels .. Front: ET55 (7" x 17") ... Rear: ET50 (8.5" x 17")
Thanks ... |
Absolutely! I use those exact wheels as my track wheels. They look GREAT on a 964.
Erick
93 RS America |
Thanks for the reply Erick ... are you using any spacers for the back wheels (5mm) ?
Actually, yes. I am using 6mm spacers in the rear to avoid rubbing issues that ONLY occur on the track. I've never had ANY rubbing on the street, but with R-compound tires (>1G corners), and lowered on a nearly stock suspension (H&R coilovers), I get some rubbing. Nothing major, but enough that spacers have solved the problem.
93 RS America |
