Recommended spark plug
Since I will be doing the valve adjustment since everything is accessible right now,
I thought this is the best time to change spark plugs too. The plug that came off the car is Beru with three electrodes. Is this the original? What do you guys use? Thanks again.
1993 964 C2 still makes me smile Retired and work as needed as a pain in the **s. |
Bosch FR5 DTC work well
AFJ
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann. Ihr Brunnen der nutzlosen Porsche Information |
Thanks.
Called around some auto supply stores to find they don't sell this Bosch plugs. I will have to do this later as I just fixed all the oil leaks and wanted to drive the car for a while. The Beru plugs looked new and clean anyway with no fouling and car pulls strong with no miss.
