Porsche approved coolant.....
After performing AT LEAST 4 different searches & not finding ANYTHING (I could be an idiot & I am sure somebody will prove it, lol) I can find nothing on what type of coolant to put in my 996.
TIA, - Cam
If there are no dogs in Heaven, then when I die I want to go where they went. -Will Rogers 1999 996 FOR SALEhttp://forums.pelicanparts.com/3788325-post1.html |
Porsche coolant, available from your dealer.
part number: 000 043 301 05 There is no specified change date. Probably if the water pump leaks would be the only time coolant would be needed.
From November 2012; Precision Porsche Specialist Sussex UK, +44 (0)1825-721-205 2001-2012 Gerber Motorsport Inc. 206-352-6911 07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red 08.16.09 1999 Kawasaki ZRX1100. Green. |
THanks,
I think I need to add some (probably just add some distilled water) to top it off. My temp light flashes about every third time I start up my car. If I stop, turn off the motor & then restart it, light is off. - Cam
Here it is...... http://www.pelicanparts.com/catalog/shopcart/996M/POR_996M_WATmis_pg1.htm#item6
Yes it's on the board sponsor's site. ![]() -Eli |
Sorry Eli, I was assuming the coolant was needed right now.
"right now". I was wondering if any "off the shelf" cooolant was "approved". Thanks, - Cam
Oh, I see.......
Hope everything worked out just in time....... -Eli |
coolant......
Not that I'm aware of......
Price we 996 owners pay vs. air cooled..... -Eli |
Thank you, Eli......
