-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/porsche-964-993-technical-forum/)
-   -   964 heater control problem (http://forums.pelicanparts.com/porsche-964-993-technical-forum/251557-964-heater-control-problem.html)
belauto39 11-16-2005 11:14 AM
Hi,
The only way to have some heat in my 1990 964 is to turn the knob completely to the right (max) on the heater control in dash. Even on cold mornings (55F), no heat with the knob set to 24C (80F).
I tried an other heater control unit and it worked OK.
I also tried to replaced just the front of the heater controller with the front of the working control unit (all buttons and thermostat) and still no heat , so it seems to be inside the heater control box.
Where can I have it tested and repaired? Vertex have some for 1299$ !!! Gulp!
Thanks to everybody.
AFJuvat 11-16-2005 07:23 PM
No real way to repair them that I know of, other than to take it apart and look for bad traces\burned components.
sorry
AFJ
BLK964 11-16-2005 07:38 PM
You may want to check your servos, before looking at the control unit itself. There's a good writeup here...
http://www.porsche964.co.uk/technical/servos.htm
That's where I'd look first. I had to replace a couple of servos on mine after freezing my way through my first winter with my car.
I don't know him or have any affiliation with him, but I believe Loren repairs these. His Pelican user id is Lorenfb. I believe this is his website...
www.systemsc.com
Maybe someone else can give you more options.
Jason
Tall02 11-19-2005 05:55 PM
Heater problem
I had a similar problem with no air blowing and I narrowed the blem down to the rear blower was bad in the engine compartment. If there is no air pressure to the servos from the rear blower then the twin cabin blowers will not come on.
This option should be the first item checked or everything else down stream will not function.
Good luck
plain fan 11-20-2005 08:13 AM
Will you front fans run (with the switch) when the temp switch is on the blue dot? If yes, then I would definitely check out the rear fan.
