jmshepard's Avatar
muffler type for 95 993
My forum research seems to indicate that a 1995 993 C2 would use the Bischoff mufflers. Can anyone confirm this?
Thanks,
Jim S.
Old 12-29-2005, 01:14 PM
jhc jhc is offline
jhc's Avatar
My 95 C2 cab has the Bischoff but some have the Gillet. The name is stamped on the muffler body.
07 997 cab sold
95 993 cab sold
87 911 cab sold
Old 12-29-2005, 01:16 PM
jmshepard's Avatar
Sadly the car has a muffler bypass pipe installed in place of the original system. The PO checked with the installer and the mufflers are in a scrap yard (or sold on ebay). The car sounds good for my tastes but it is a little too strong for the neighborhood and more importantly, the spousal unit.
Is there any other way of determining the OEM of the mufflers on this 993?
Thanks,
Jim S.
Old 12-29-2005, 05:59 PM
Jbabic's Avatar
Hey, send me pics I may want to take those off your hands and trade with my original mufflers plus cash... I like loud porsches!!
Old 12-29-2005, 06:36 PM
jmshepard's Avatar
I'll try to post the images this weekend.
Old 12-29-2005, 07:03 PM
maxnine11's Avatar
Jim, all of the 993 mufflers, Gillet and Bischoff, are interchangable throught the 993 model range.
It is the shape of the flange between the heat exchangers and catlytic converter that differs between the two suppliers.
The exhaust tips (offset) also vary between the wide bodies, Twin Turbo, and standard Carrera.
If you want a little more 'sound' than stock- and i know you do - you might want to get a set of RSR mufflers. Unfortunetly, you have to supply a set of cores as part of the deal http://p-car.com/exhaust/
I have the RSRs and the drilled motorsound airbox lid which combine to make a very nice sound once you are on the throttle, but are far from obnoxious when at idle or low throttle input.
Good luck,
max
max
Old 12-29-2005, 07:39 PM
Max is right, mufflers themselves interchange, but the cat and heat exchanger are dependant on vendor, Gillet or Bischoff.
How ya doing Max? Long time no talk..
Old 12-29-2005, 08:08 PM
