Differences between 996??
Hi,
Just thought I'd shoot out a quick question on the main difference between the early 996 and the 2002 model? I was at the dealership and they both have the 2001 C4 and the 2002 911. I can't tell the difference between the body style. I know from reading the specs the '02 has alot more power, but in terms of the bodywise... Is there a difference?? Hope I get some feedback.. ~onsse |
I think the 2002 had a glovebox, where the earlier ones did not.
Otherwise, the engine is the main difference. AFJ |
The 2002 has the 996 Turbo headlights. Changes were also made to the front and rear bumpers which were supposed to make a signifigant improvement to the Aero of the car.
The engine in the 2002 put out 320 HP-the 2001 made 300. I don't think I would call that " a lot more power". |
thanks... went in ebay and found very slight differences in the headlight and bumpers that was pointed out. not much difference at all... except for the price :-(
~onsse |
2002 + is supposed to be a stiffer car. They also have a glove box, cup holders, and I believe the turbo twist wheels became hollow, thus less unsprung weight.
I loved my past 2001 C4. No problems with it. |
I'm sure performance wise - there will be differences. But nothing that aftermarket parts can't keep up with. i.e, suspension and wheels.
Im just trying to figure out if its worth spending an extra 10k-15k for a 2002. ~onsse |
-Eli |
lets see.. a glove box, a semi egg shaped headlight, a supposedly improved suspension, colored bumpers for aerodynamic look, and 20 ponies added.. hmmmm
| All times are GMT -8. The time now is 06:46 PM. |
