Steering Wheels Spacer
Does anyone know if there is any company that sells a steering wheel spacer for the OEM 964 steering wheel? Once I get the seat in the right place, the wheels is a smudge too far away...any leads are appreciated. Thanks.
-Stan
1993 RSA #164
Old 02-26-2006, 10:48 PM
Try AJ-USA or FVD.
Old 02-27-2006, 03:13 AM
Thank you! I found two at FVD and am waiting for AJ-USA to return my e-mail regarding whether they carry any...thanks again!
-Stan
1993 RSA #164
Old 02-27-2006, 07:58 AM
Welp...I'm still in the hunt. The spacers that were available, were not for use with OEM steering wheels. I want to retain the OEM wheel and the airbag...not that I don't like some of the nice three spokes out there, including some of the OEM Porsche ones that apparently will fit, I just don't want to spend a lot of money on a new wheel. If anyone has any input on my "problem", I'd be most appreciative. At this point, I've been told that the thread on the steering column, to hold the wheel in place, is not long enough to retain the steering wheel, after you try inserting a spacer, so, that's my problem at this point. The car is a standard US spec. Thank you.
http://img150.imageshack.us/my.php?image=rsa046af.jpg
-Stan
1993 RSA #164
Old 03-06-2006, 08:13 AM
