964's DIY friendly?
Having owned pre-1969 911's for many years, I'm thinking of getting a newer Porsche. I'm finishing up a restoration on my low-mile-super-original 1965 911 and already it looks too nice to drive. So IF I sold that, I was thinking about a C2.
I've done all my own maintenance for years and was wondering how it is to work on a C2. Is routine maintenance out of the question? Can I do a tune-up? Are somewhat simple things like valve adjustments all-day difficult? I've read about the flywheel, distributor vents, and head leaks of early C2's so I'd look for those to be done already. Any insight would be beneficial. Thanks,
Nate |
I've done pretty much all my own repairs and maintenance for 10 years; most things I've had to fix are wear items: brakes, etc. which is a testament to the 964's indestructability. DME system diagnosis without a Hammer is possible but not surefire, but neither is the Hammer.
The only stuff you'll need a Hammer for is hydraulic flushes; I've got a C4 that needs a Hammer for that (ABS and diff locks), C2 might need it for ABS. Dealer stuff. Sparkplugs take a few hours (12 of them, and need to remove alot of stuff to access). A few more nuts and you can access the valves for valve adjustment (1-2 more hours). But honestly I haven't adjusted my valves since 150k miles and I've got 200k now - still runs quiet and strong. |
ditto on colo964. done all my own maintenance and engine rebuilds on all cars I have owned. 69 912, 73 vega, 69 2002, 60 mga, a chevy 350, volvo 740. I like the 964. Get the factory manuals. Sounds like you probably have all the tools you need.
Some addons are really easy: rear fog lights and daytime running lights. I have bought all I need to add headlight washers and will do that later this year. Valve adjustment took me most of a day, but it will last 50k miles. brakes are a snap, even changing struts and axle shaft boots are not a big deal with right tools. Just changed my turn signal, washer, OBC and cruise apparatus around the sterring column in about 2 hours. I have 160 k miles on mine. I would go for a 92 and above as a first cut.
steve old rocket inguneer |
I do have a wide assortment of tools so I think I'd be safe there. I've briefly heard about something called "The Hammer". Is that a computer or special diagnostics tool? Is sounds $$$, is it and would I need it? Why a '92+? Yes, I like the mirrors of the newer C2's but are there other items (head gaskets, flywheel, etc.)?
Nate |
Why not get a 993? No valve adjustments. Or better yet a 996 (same price as the 993). The 996 is a breeze to work on and I've notice parts are relatively inexpensive.
Armando Diaz 85 911 Carrera - Track car 01 996 Carrera - For Sale http://forums.pelicanparts.com/showthread.php?s=&threadid=327823&highlight=996 87 944na - Old Daily Driver, now 944 CUP 03 Chevy Avalanche- Support Vehicle 70 Olds 442 W30 Conv- Gone but not forgotten http://www.diazracing.com adiaz@diazracing.com |
