C4 front inner cv joint
Has anyone done a DIY rebuild on the front inner cv joint on a C4? I'm replacing my front inner cv boots on my C4, I got the cv joint with out any problems. Now I can't reassemble the cv joint, do I need to have it pressed back together. Does anyone know how to reassemble the front cv joint on a C4, or know if a shop can press the cv joint back together for me. I did the rear inner cv joints and I had no problems at all.
You might try www.rennlist.com and go to the forums
| All times are GMT -8. The time now is 10:51 AM. |
