 2 newbie questions first Porsche.  1992 964 Carrera.  some dumb quesitons: what grade of gasoline should I use? getting a 964 with 60k miles. should I do a 60k mike "check-up"? what are the major things I should have checked? |
 Premium If it has not had it's 60k service, you should have it done. It's a "major" service with plugs changed (a real PITA), valves adjusted, etc in addition to an oil change. Did you have a PPI done before purchase? Did you get service records from the seller? If you answer no to both questions, you should make sure you get it to a good Porsche shop and have it get a thorough service and inspection. |
| All times are GMT -8. The time now is 06:52 PM. |
