91 C2 Alarm Bypass
Anyone have a clue how to bypass it? I have a car here 91 C2 turbo had a wiring short requiring a few of them to be replaced. All is well with the wires now with continuity checks on all damaged wires checks out ok. Prior to the inceident the alarm was going off on its own an not shuttin off but the car was drivable. None of the wires to the alarm were damaged and everything works in the car and the car runs when the Supply wire to the DME is fed 12v constant the car will run. I have tried to disable the alarm using the unlock method amongst other techniques. I am wondering what is the proper way to defeat this stupid alram box so everythign works and is happy. Or if anyone can help out with the cars wiring diagrams that would be killer as well.
Thanks! |
| All times are GMT -8. The time now is 05:03 PM. |
