-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/porsche-964-993-technical-forum/)
-   -   Installing H&R Springs in 996 (http://forums.pelicanparts.com/porsche-964-993-technical-forum/287235-installing-h-r-springs-996-a.html)
Royracer930 06-08-2006 10:18 AM
What is the degree of difficulty and how long should it take to install a set of H&R's in a 996 carrera, any pitfalls to watch out for ?
many thanks, Roy
mattr_914 06-08-2006 10:55 AM
Springs really arent too bad. I'm assuming its a 2wd? A 4wd is a little more difficult up front. You'll have to access the tops of the dampers from the interior in the rear which will require the removal of some interior pieces. Just be careful (obvious) and remember all the little plastic tabs can be ordered through porsche. Also, you can loosen the links in the suspension to get flexibility and not take them all the way off. You will need a full alignment afterwards too.
