Porsche Crest 964 Cab Roof Light. Hmmm, Interesting
Anyone else have this problem with there 964 Cabs.
Well it's not a Problem at all but I didn't realise it till now.
If you have the roof down all day and then come home and put her back in the garage and put roof back up again then disconnect the battery as you are not going to be using for a few weeks. The next time you go to use her the Roof light will stay on UNTIL you open the roof a little and close again, and then it will go out. The same thing will happen again if battery disconnected. Interesting huh. It's almost as if the computer for the roof cannot remember if it was last open or closed when battery was disconnected so light stays on.? Anyone else found this with there 964 cab aswell. Cheers.
Old 07-15-2006, 06:11 AM
