91C2's Avatar
OEM radio
My OEM radio does not work when I enter the code but there is no response or the the radio will does not change when I enter the code.
I noticed that this has an amplifier under the passenger seat. What is the easiest way to install a new radio?
1970 Morris Cooper S, 1973 Mini Clubman GT, 2008 BMW 135i Coupe, 2008 BMW 128i Cabriolet, 1995 BMW M3, 2016 Mazda Miata
Old 02-15-2010, 03:03 PM
Do you have a new stereo head unit in mind? If you do, it's pretty much just a matter of sliding the old one out, and plugging the new one in. Just make sure you measure the new one well before you buy, so you're sure the faceplate will fit.
If I remember right the OEM radio has the same method of removal as the climate control unit...there should be a set of holes on either side that you use to pull it out with. I cut apart either side of a wire coat hanger to get my A/C unit out when I was fiddling with it.
If your amp and speakers are still stock, you might consider upgrading those as well too. Speakers go limp after a while (mine definitely are), and the stock amp isn't anything special.
1990 Carrera 4 Cabriolet (silver with black canopy, white leather interior)
2004 Nissan xTerra (Black)
Old 02-15-2010, 09:24 PM
gbc gbc is offline
the stock head unit/speakers/amp are weak and produce low quality sound.
installing a new head unit and retaining the stock amp (which is exceptionally bad) and speakers imo is questionable.
you may be well advised to fully upgrade the system and while you are at it install an i-pod dock or mp-3 dock in the glove box.
Old 02-17-2010, 07:27 PM
Does anybody have experience wiring an iPod dock to the glove box? I just put in a new stereo myself, and I've been trying to figure out the best way of doing it.
Old 02-18-2010, 10:40 AM
91C2's Avatar
Thanks guys, what I am trying to do is keep it as original as I can, I would not mind buying the OEm radio from anybody in this forum.
Old 02-18-2010, 07:17 PM
91C2's Avatar
Thanks guys, what I would really like is if any of you are selling their OEM radio for a good price I would not mind buying one.
Old 02-18-2010, 07:19 PM
91C2's Avatar
Does anybody know where I can send my OEM radio to be checked?
Old 02-28-2010, 08:08 PM
I just put in a new Alpine unit. It has an extension cable that I routed into the glove box via a small hole I drilled into it in the top left corner. I just plug into that and lay the iPod in there, mine has a rubber sleeve, so it doesn't slide around. The glovebox is rather thin plastic, so I doubt that you could do anything hard mounted.
89 C4
Old 03-08-2010, 01:22 PM
If it's a Becker, go here: index
I had luck with them checking out my Boxster radio a few years ago.
89 C4
Old 03-08-2010, 01:29 PM
Cool, thanks! I figured that's probably what I'd have to do in the end, but it's always good to check options before you start drilling.
Old 03-08-2010, 08:43 PM
Just took some pics today, here is how I did it. Now I can hook up my ipod, or, I bought one of those Porsche zip drives that looks like a key, so I can even load songs onto it and plug it into here. Really cool.
89 C4
Old 03-12-2010, 11:44 AM
91C2's Avatar
Still looking for an OEM radio or a place to send the factory radio
Old 02-28-2011, 09:30 PM
gbc gbc is offline
you might try over at rennlist to see if anyone has upgraded. basically the complete original audio set up in these cars (considering their street price when new) was bottom end , head unit, speakers, & especially amp....so most who are interested in decent sound (especially cab owners, highway speeds!) tend to upgrade. got to be lots of this stuff around.
if you are committed to original, good source will also be dismantlers, perhaps here
dC Automotive - Your used/recycled Porsche Parts resource
Old 03-01-2011, 04:28 AM
91C2's Avatar
Thanks, I do not really care about the sound as long as it works. I have learned to live without some decent music.
Old 03-01-2011, 07:40 PM
91C2's Avatar
Thumbs down
Okay you guys win I just bought a new head unit from crutchfield. I am able to mount the radio no problem it is the wiring that is different. The OEM radio only had a few wires and a round black plug with pins on it.
Is there an adaptor for this plug? Any help is appreciated, thanks
Old 05-14-2011, 12:48 PM
The round plug is a DIN plug - a German standard. There are adapters out there that for purchase - you may want to try Crutchfield.
This may also help:
964 Audio System Updgrade - Guidance Please!
Have fun.
'91 C2 Targa
Old 05-17-2011, 07:33 AM
91C2's Avatar
Awesome link, I just need to know what are the other wires, which color is for power etc.
Old 05-19-2011, 09:35 PM
