1999 911 cabriolet: how to repair/re-glue rear window?
The Texas heat and sun has caused the rear window to pull away from the top (at the bottom edge of the window) on my 1999 911 C4. Any suggestions on how to fix or has anyone had good results fixing this problem? Can it simply be re-glued, if so, what kind of adhesive? Are special tools required?
Thank you, in advance, for your replies.
Old 08-08-2006, 10:50 AM
