Intermittent Speedo
'95 933. I'll get in the car and take off, speedometer stays at 0, hit a minor bump in the road and it jumps to life and stays working until the car sits for a few days. Loose connection and possibly some corrosion I assume? Any suggestions on where to look? Would also love a basic education on the components and locations.
'95 993 C2 Black |
HI try on the side of the gearbox (your drivers side)for the speedo sensor connection??
regards mike |
I think what I'd look at first is the electrical connections behind the speedo - in particular the ground. You can remove the speedo with your hands by pulling or twisting the face, or by using electrical cord as a strap wrench. If those connections don't fix it, then try as Mike suggests.
Don Plumley M235i memories: 87 911, 96 993, 13 Cayenne |
I think I once lubed a speedo cable on a car that was doing this. I just disconnected the cable from the back of the speedometer and let some lube flow down the cable. It might be worth a try before you replace your speedo or open up the gearbox or something drastic.
Downshift |
Yep, Monday morning got me again.
Nevermind.
Downshift |
Monday morning!!!!! it's nearly bed time, have you slept in??
mike |
