dhf dhf is offline
DHF
carrera 2 converible
I have a 1990 Carrera 2 convertible and am having problems with the front locks on the top. Does anyone have the procedures for adjusting these? I have the workshop manuals, but convertibles are barely mentioned.
Old 09-10-2008, 11:38 AM
They rarely (if ever) require adjustment. What is the exact problem with the roof?
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 09-10-2008, 05:05 PM
My cab top messed up too.
The top has a logic contol box which controls the 2 up/down motors, 2 lock motors for the lock up to the windshield 2 or 3 end switchs for the up/down motors, and 2end switches for the top lock up.
From other cab owners, a weak link is the control box which has a circuit board cold soldered inside its VDO case. The cold soldered joints can be resoldered, if I recall at the tie in to the input/output wiring terminals. This solved many problems which I read about on this or another forum.
My problem was solved simply by going through each end contact and making sure there is continuity, or good contact and not a bad end switch. Perhaps your problem could just be a loose end switch.
My up down motors were also loose internally and needed to be tightened up internally. I got a chuckle when I opened the housing and saw the BMW logo on the part.
My documentation from Porsche says any problem with the arcanaries of top operation require dealer technician time. I just swap till I drop with a little help from my friends on line.
Old 09-10-2008, 05:13 PM
dhf dhf is offline
DHF
The left lock down motor works but the right one does not. The dealer replaced both motors and switches.
david
Old 09-15-2008, 07:08 AM
