Looking for an eProm for 964 and KTS-300
Title says it all. I have a line on a KTS-300. Has all pieces parts except for the eProm (minor detail). Hopefully the lower side of expensive.
Old 10-29-2006, 11:37 AM
i have just purchased a new chipfor my 964 from Steve wong What is my stock one worth? johnsjmc@sympatico.ca
1980 911 SC 3.6 coupe sold
1995 993 coupe
1966 Mustang Shelby clone
1964 Corvair Spyder Turbo gone
2012 Boss 302
Old 11-06-2006, 05:05 PM
Wrong chip. The ePROM I was refering to is the card that goes into the KTS300 for reading codes and resetting things. Over on Rennlist there now a Scantron system that works with a laptop doing most everything the Hammer does.
Old 11-07-2006, 03:38 AM
Craig. That DIY Interface that you talk about on Rennlist is excellent. I have just finished building one to talk to my 964 and it's amazing. So to all you guys having problems with the electronics on your cars than maybe you should check it out as it's dirt cheap to make and does pretty much everything Including erasing codes as well, YES thats right, if you have fault codes in your memory than you can now erase them for yourself without having to pay someone else to do it for you. I have built this and can assure you it works perfectly. Give it a go.
Don't need the KTS 300 no more Craig.
Old 12-04-2006, 02:00 AM
I know about the Scantool you are talking about over on Rennlist. My lappy is a newer one without a serial port so I would need to get a Serial Port Adapter Card or just buy an old laptop with the port and just have a dedicated computer for the car. Which are you using, adapter card or older laptop?
Old 12-04-2006, 06:47 AM
I am using both Craig. It's not an issue for me as I have computers all over the place at home and at work. My laptop is great when I need to monitor things aswell as drive at the same time and a desktop does the job for anything else. Both work as good as each other though. When using my newer laptop then I need to use a usb to serial adaptor which isn't fantastic as the baud rate becomes a problem with the motronic but thats why I use my older laptop with the serial onboard when I need to use it mobile. It's great.
Old 12-05-2006, 12:57 AM
What version of Windows are you running with the SCANTOOL?
Old 12-05-2006, 03:01 AM
xp pro
Old 12-05-2006, 03:41 AM
