Air Flow For Heater Blower
Hey all, 1990 C2 Cabrio here, , when I turn on the heater, center left vent and passenger side work great, good airflow, lots of heat
Drivers side and right center, not so much, very, very limited drivers side blow and it seems kinda cool. Strange.
Any ideas? Is there a damper somewhere I'm missing that may have gotten closed somehow?
Yes, for you smartasses, the vents are open (First thing I checked).
Semper Fi,
James
Have Porsche and small wallet!
Old 10-13-2006, 09:03 PM
I would target the little electric motors that move the vents inside the airbox. The vents control the air mixture for cold/outside/heated air within the car. It sounds like the vent that controls this mixing is not working (possibly disconnected from the motor or arm). Check inside your trunk. With the car off turn the temp knob to full cold, turn the ignition switch on and watch the control arms. Then with the car off turn the knob to full heat; turn the car on and watch the control arms. If nothing happens you may have a bad motor on that side.
Grady aka plain fan
66 912 - enjoying the good life
78 911 SC and 90 C2 turbo look cab - gone but not forgotten
01 996 TT -
09 Audi A4 Avant - daily driver
Old 10-14-2006, 11:18 AM
Send a message via Yahoo to FRED/LI
Try the Pcar.com site. I believe there is a servo tutorial dealing with this.
Fred '95 Carrera2. Previous: '69S, '79SC, '84Carrera, '90 C2, 20+ years and counting......
Old 10-15-2006, 06:15 AM
Back in New England!
MattAlpha's Avatar
Send a message via AIM to MattAlpha Send a message via MSN to MattAlpha
James,
If you don't get this figured out this week, I can swing by this weekend to try and help.
Give me a call,
Matt
'78 RoW 911SC Targa converted to a '86-like 3.2L Cab (w/930 body & No A/C) Custom subframe integrated into AutoPower Half Cage, Euro Ride Height, Turbo Tie-Rods, WeltMeister Bump Steer Kit, Sway-Away 26mm Rear Torsion Bars, Koni Adjustable Shocks and Strut Inserts, Two Bar Rennline Strut Tower Brace, Poly Motor Mounts, WEVO Trans Mounts, Modified Conical K&N Intake, ER PB A-arm bushings and 17" CUP3 Wheels. Steve Wong Chip!
Old 10-16-2006, 08:01 AM
Matt,
You just want to rub against my shiny red car, homo!
Old 10-16-2006, 08:14 AM
