eki912's Avatar
996 amp wiring
I got no replies for my doorspeaker question earlier...
I bet someone must have done it...
Another , getting deeper and deeper.Trying to build a sub....
The amp , on 490 option , is run by this BECKER cdr220 unit. It has a line-out jack. I called a specialist , he said if you have another amp (which I have ) , that line-out is used and you cant use that anymore.
OK , I crawled in to the trunk , pulled the amp & wires. Had a wiring diagram in my hand , and to me it seems that instead of line-out , they have used the speaker outputs to run the amp !!!
So all 4 channels come to amp , and 6 comes out.Does this make any sense at all ?
So I presume , that the line-out option is still available for me to use ?
And : how to take off the unit ?
Thanks for any tips !
e k i
Old 10-18-2006, 03:46 PM
